Your thoughts on this neck?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=43860
Page 1 of 2
Author:  DarrenFiggs [ Mon Jul 21, 2014 10:03 pm ]
Post subject:  Your thoughts on this neck?
http://deanzelinsky.com/pages/z-glide
Author:  DennisK [ Mon Jul 21, 2014 10:27 pm ]
Post subject:  Re: Your thoughts on this neck?
Pretty cool! I do prefer lower gloss, open pored necks for the same reason of having less suction grip. But I'd have to feel the texture to see if I really like it. I hate scritchy satin feel.
I wonder how easily it cleans up after accumulating finger grunge for a while.
Author:  Chris Pile [ Mon Jul 21, 2014 11:40 pm ]
Interesting, to say the least.
Author:  Clay S. [ Tue Jul 22, 2014 7:58 am ]
"The Z-Glide was also designed to trap moisture and sweat."
Yuck!
Author:  Glen H [ Tue Jul 22, 2014 8:29 am ]
It is interesting. Innovative. But I agree with Clay... I wouldn't promote it's sweat and moisture trapping properties as a feature.
Author:  jfmckenna [ Tue Jul 22, 2014 8:38 am ]
Well at least I have an excuse to charge triple for cleaning a guitar :D
The idea is novel, maybe even true, but no thanks. I think a stain or an oil finish or a light shellac finish with no build up, maybe even burnished, would feel just as fast.
Author:  Tai Fu [ Tue Jul 22, 2014 9:53 am ]
You could achieve the same effect checkering a guitar neck like gun stocks... the checkering is designed to improve grip however.
Author:  Barry Daniels [ Tue Jul 22, 2014 10:26 am ]
Gimmick. The lessened surface area would reduce friction, but all the grooves would increase roughness which would likely counter any beneficial effect.
Author:  DarrenFiggs [ Tue Jul 22, 2014 3:16 pm ]
Exactly my thoughts, Barry.
Author:  Lonnie J Barber [ Tue Jul 22, 2014 3:17 pm ]
Looks kinda ugly to me
Author:  Michael.N. [ Tue Jul 22, 2014 3:25 pm ]
I wasn't aware that so many folks had problems with the thumb sticking to the back of the neck. Maybe next time they should wait until the varnish is actually dry.
Author:  wbergman [ Tue Jul 22, 2014 5:34 pm ]
Years ago I saw some high end classicals (can't recall the name) with ebony veneered to the back of the neck and no finish, the idea being to reduce the grab of high glass, which I think is why violins have no finish on the contact parts of the neck.
Author:  wbergman [ Tue Jul 22, 2014 5:39 pm ]
This appears to be manufactured by Dean, of Dean Guitars. The mailing address is in Northbrook, Illinois, if anyone in the Chicago area want to arrange to try one out and report to us. Years ago, I used to live one block from the original Dean shop.
Author:  James Ringelspaugh [ Tue Jul 22, 2014 6:36 pm ]
I prefer the textured feel of an open pored satin or semi-gloss shellac finish myself but I can't say I ever notice it when I'm actually playing. A high gloss finish certainly doesn't slow my left hand down.
Maybe I'll paint some flames on my next neck and see if that makes it play faster.
Author:  theguitarwhisperer [ Tue Jul 22, 2014 6:41 pm ]
Dean Guitars is headquartered in Tampa, which is where they also have their Custom Shop manufacturing facility.
The ones in the OP are imported by Dean Zalinsky, to his specs and designs, and has nothing to do with Dean Guitars the company anymore.
Author:  wbergman [ Tue Jul 22, 2014 7:52 pm ]
Yes, I know Dean Guitars sold out years ago. Is the subject of this posting operating out of Illinois? Does anyone know where to try one of these out?
Author:  itswednesday14 [ Tue Jul 22, 2014 8:12 pm ]
Gimmick, it would do exactly the opposite of what is advertised. Besides I like high gloss necks. They are the fastest for me. YMMV
Author:  John Sonksen [ Tue Jul 22, 2014 11:19 pm ]
I bet it works, same principle as a golf ball or a santoku style knife. I don't think the texture on that is really like the knurling, diamond patter that you see on gun stocks which effectively raises sharp points of contact up from the surface to provide grip. This looks like the high points are all planar to the outside curved, carved section of the neck and are meant to reduce surface tension when an object with a light fluid, such as the oils or sweat on your hands moves across a smooth surface. It's like cutting a potato with a traditional chef knife, the potato sticks right to the blade. When you use a scalloped santoku style knife though, the reduced surface tension doesn't allow the potato to stick so it just slides right off. I haven't tried one, and I'm not sure it's as big a problem as the maker would have you believe, but I do bet that it works.
Author:  Kamusur [ Wed Jul 23, 2014 1:32 am ]
Guess that some are always trying to push the boundaries, rightly or wrongly. Not everyone succeeds so it looks like try and see, sure looks ugly though.
Author:  Michiyuki Kubo [ Wed Jul 23, 2014 3:24 am ]
Will cause more friction as previously said. Golf balls dimples cause the ball to spin, the spin is what makes it fly better. Santoku knives have air cavities not so it is a smoother cut but so that the flesh separates and not stick to the blade.
Author:  SteveSmith [ Wed Jul 23, 2014 8:47 am ]
Yep, ugly.
Author:  Don Williams [ Wed Jul 23, 2014 10:29 am ]
I believe that most folks would just use a satin finish or tru-oil finish if they don't like the gloss lacquer feel...
But what do I know?
Author:  John Sonksen [ Wed Jul 23, 2014 10:26 pm ]
okay, I'll give you the aerodynamics on a golf ball, but I never said anything about a santoku making a smoother cut, I did say it was to reduce the surface tension of the knife to what you're cutting. Maybe a better comparison would be between machinists gage blocks of high quality versus those of low quality. You can wring together the gage blocks with a finer surface finish to a much greater adhesion than those with poorly machined surface finishes. It's because the finer surface finish allows for greater surface to surface contact, which is the same principle at work here. I'm not a proponent of these necks, and I think they're ugly too, but I disagree that it will actually have the reverse effect of what they're claiming. If anything the improvement may be overstated, but I have to say I don't agree that this is the same as putting a diamond finish or knurl onto a surface to increase friction. It would be pretty dumb to go through the trouble to design it, the added expense of making it, throwing more money into advertising it, for it to actually make it worse than a regular neck. Just doesn't make sense to me. If it was worse and stickier, just abandon doing them that way...
Author:  Barry Daniels [ Thu Jul 24, 2014 10:31 am ]
Actually the dimples on a golf ball reduce friction and allow it to travel further. They do not make the ball spin more.
Author:  Tai Fu [ Thu Jul 24, 2014 10:41 am ]
I think they even tested it in mythbusters, they put dimples into a car and it improved fuel efficiency.
